Samsung WW80J555FX/EU
Hi all,
My Samsung washing machine is playing up.
It will run it’s cycle, filling, washing, rinsing, it will even start to spin, but when it gets to 5 minutes left on the spin cycle, it stops , the display goes back to 13 minutes and it just stops. You then have to switch it off and wait before you open the door. It spins fine gets to 5 minutes , then the drum slows down, it makes a kind of glug glug sound, then just freezes and goes back to 13 minutes, the drum stays still and you can’t hear the pump running.
I’ve cleaned out the filter and all seems ok.
The pump has 2 impellers on it, one at rear and one on the side, should both run together as I’ve only seen the rear one spin.
Anything else I can try, anyone got any ideas?
Its not showing any fault codes
Any advice greatly received.
Cheers Paul
