Samsung Ecobubble WF8702RSS
  • #99671
    chuffy
    Bit of a strange one.
    Was called out to this machine because when it has completed the programme and you turn the drum by hand is sounds like there’s still some water in the tub and it’s catching the drum as you rotate it.
    I’ve emptied the machine completely by removing the filter and sump hose and no restrictions/blockages were found.
    Then with the tub still empty you still get the same “sploshing” sound when moving the drum around.
    I’m mystified…..anyone else come across this phenomenon?
    #477312
    looks like its not direct drive so did you remove the belt and try turning then
    has to be mechanical problem
    chuffy
    No Dave it certainly sounds like a water sploshing around.
    Exactly the same sort of noise you get when there’s an inch or so of water left.
    It’s not mechanical resistance from drum or motor.
    Almost like there’s a container containing liquid attached to the drum and out of sight.
    very wierd!
    #477314
    well the only thing i can think of is the paddles full of water or are they using a liquid conterbalance
    chuffy
    Yes paddles full of water is what I was thinking but I’ve never come across that before because most paddles have holes in them.
    Not really sure what you mean by a liquid counter balance.
    #477316
    chuffy
    Just watched a video on YouTube that shows replacing the balance rings which are fitted to the drum on Samsung washers.
    Not sure how they work but they are not a listed part on this model.
    Look like hollow plastic rings I’m and not sure if they fill/partially fill with water in use.
    #477317
    like this
    https://www.youtube.com/watch?v=yIvNVEflO20
    this is maytag but same principle
    chuffy
    Interesting
    But still confused.
    #477319
    adv
    Only they could come up with something so stupid ..
