samsung error code problem
Home Forums Public Support Forums Help And Support Washing Machine Help Forum samsung error code problem
  • #88479
    carmine
    My Samsung washing machine is just 4 years old and has stopped working showing error code 1E ,I purchased from you a new water inlet valve and fitted it but the machine is still showing error it is strange because it shows error before machine starts I have tried disconnecting from the maina and leaving two days but error is still there is there anything you could suggest to clear this error signal or is the error a different one thank you for any advice :con:
    #438288
    don
    Re: samsung error code problem
    Can you post up the model number please 🙂
    Don
    #438289
    carmine
    sorry here is model no. WF8800BPH1/
    #438290
    don
    Fault code guide says:
    E1 Not filling in allocated time
    This is essentially a fill timeout error which will normally mean that either the water isn’t on or that an inlet valve has failed. We do list the generic water inlet valves for Samsung washing machines in this section and, if you’re clever you can use one of those by altering the connections but, if you need the genuine one specific to your model please contact us.
    So valve was first port of call so there must be another issue as to why. I would have an engineer out to have a look as I think it’s past the DIY stage.
    HTH 🙂
    Don
    #438291
    carmine
    thanks for reply Don I wondered if the error has blocked on as it shows before machine starts cycle is there a way of removing error code tried unplugging machine left for couple of days but minute you tur on and try to start the machine goes straight into error,could it be a contr ol panel error
    #438292
    don
    It could be, the only way of being sure is for an engineer to take a look.
    Don
