Samsung F/F RS20CCSN
  • #30351
    a1al
    Hi Guys
    Called out to this today customer says frez and fridge keeps getting warmer (food in freezer defrosts) and then in two or three days returns to normal, I think I have done test but could not get it to show any faults.
    many thanks for any help
    Alymer
    #226867
    Re: Samsung F/F RS20CCSN
    Hi A1
    The problem is with the defrost system..check the heater,thermal fuse and change the defrost sensor.
    Bryan
    #226868
    a1al
    Thanks Bryan
    Does the system check these? or do I have to test them manually and if so do you know what reading I should get
    Alymer
    #226869
    robbo1973
    the fault will be with the heater in the fridge i have had this fault loads be sure to disconnect tray heater when testing.
    chris.
    #226870
    funkyboogy
    dont think the rs 20 has evaporator in fridge..
    it all comes from freezer side,
    if so check defo heater etc @ frz evap..
    this fault seems to be inherent with the rs20 models…
    cold air blown into fridge >>>>warm air back from fridge via tunnel,
    return tunnel condensates and eventually will block up with ice, thus stopping air flow ..
    doesnt seem to be a cure for this, as the appliance is doing what its told to do..i guess samsung forgot about what to do with the warm air coming back from fridge???
    ally
    #226871
    a1al
    Thanks for all your replies
    will post outcome after I have done call
    Alymer
    #226872
    a1al
    Sorry with late reply
    But customer did not want it repaired at the time ( I think she wanted a second opinion ??) rang back recently for repair and the defrost senor seems to have done the trick
    Thanks everyone
    a1al
