Having a bit of bother with this one ,reaches temperature on fridge and freezer side ,then seems to stop .No sounds from compressor or fans.If you unplug and plug back in it reaches temp OK .No ice build up in fridge ,defrost heater and cut out OK.Suspect P.c.b but front or rear ?
HI ,I think I Found the problem with samsung F/F SR S2028DVW .The freezer defrost element was reading 21 omhs ,I know the fridge defrost element should read 48 ohms ,is it the same for the freezer element ? I think it gets to the defrost cycle then does not come back on because it does not reach defrost temperature.What do ya think ?
