Samsung FF
  • #27755
    S1MON
    SR-L3928B 424441AT600159K
    Got this through today, fridge is freezing everything and it apppears the baffle isnt operating correctly. Turned m/c off then back on and baffle rotated then stopped. I put it back together turned it back on and am now getting RD as a fault code?????
    Any ideas i take it both are related i hope 🙂
    #215476
    gegsy
    Re: Samsung FF
    Problem with the damper motor ie -CONTROL RELAY of DAMPER MOTOR
    disorder or MOTOR,REED S/W, MAGNET disorder. Which ties n with your fault, probably ice jammed the flap 😥
    funkyboogy
    Re: Samsung FF
    evaportor cover req, comes as a complete assy,
    ie fan damper motor, i would change sensor and thermal fuse as well.
    ally
    #215478
    Re: Samsung FF
    Hi simon
    The fault will only lie with the evaperator cover( DA97-03797B ).
    Sad when you can run the part numbers off your head isnt it !!.
    the sensors wont need to be changed on this model as its a different factory to some of the other models.
    Bryan
    #215479
    S1MON
    Re: Samsung FF
    ok cheers thats what i ordered……. 😀
    #215480
    TeeMyob
    Re: Samsung FF
    Hello there,
    Is this part (DA97-03797b) complete with new damper motor? or is there a part number for a modified complete assy with damper motor?.
    I know there was a problem with some of these covers, GBDar cannot seem to locate a part number. I remember Gavin Mcdonlad of Samsung saying there is a part availbe but I don’t do part numbers¬!
    Any help?
    Trev.
