Samsung fla WW90K76150W won’t energise empty pump or fill valves Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Samsung fla WW90K76150W won’t energise empty pump or fill valves This topic has 2 replies, 2 voices, and was last updated 2 years, 3 months ago by neon_3SP_glow. Viewing 3 posts - 1 through 3 (of 3 total) Author Posts December 12, 2023 at 11:39 am #102436 neon_3SP_glowParticipant Samsung washing machine WW90K76510W Called after machine stopped mid cycle full of water. Spin cycle completes program but doesn’t energise drain pump. Drain pump not open circuit. Wash prog shows C4 error after a couple of minutes indicating water supply fault. Water Supply and valve fine, not energised from module. heating element is fine. Anything I haven’t considered before replacing expensive module, thanks. December 13, 2023 at 9:48 am #488832 electrofixModerator have you had a good look at the pump to make sure its not blown the board have a careful look at the board and see if you can see any damage. look around where the pump and valve wire is plugged in Dave January 8, 2024 at 12:48 pm #488833 neon_3SP_glowParticipant Thanks Dave. The customer decided to replace the machine, so I never got a chance to investigate the board. What you are suggesting sounds very likely though, thanks. Author Posts Viewing 3 posts - 1 through 3 (of 3 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
