Srl DA99-00853D
Fault fridge freezing and destroying the beer…
Customer rang about a month ago and I told her to defrost thoroughly… it’s been off for 3 weeks and had the same fault again.
I went to it the other day. Removed evaporator cover in freezer, turned it on, baffle rotated a few times then, then stopped in the almost closed position (only partially open)
On control panel 5 horizontal lights – lights 2-5 flash.
Is this a fridge thermistor/pcb or baffle control fault??
I couldn’t find the fault codes for it.
