Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Samsung – Fridge Freezer
- This topic has 8 replies, 4 voices, and was last updated 19 years, 1 month ago by
pebly.
February 27, 2007 at 10:54 am #25408
pebly
ParticipantSamsung – Fridge Freezer
Model Number: SR-S2028CVWI have had this side by side refrigerator for some time and it has
> always been a bit noisy while in operation. Recently however this
> noise level has increased fairly dramatically and while the fridge
> appears to be operating well in every other respect the noise level is
> becoming intolerable. I assume this has something to do with the motor
> and could be resolved if the motor was replaced but I’d be keen to
> know, before committing to the potentially significant costs involved
> in a call out from an engineer and the replacement of parts, that this
> is a problem that can be resolved at a reasonable cost.February 27, 2007 at 11:18 pm #205730helo_75
ParticipantRe: Samsung – Fridge Freezer
defrost it for 48 hrs – itll probably cure it!!!
long term? if it persists, it’ll need a thermal fuse, and evaporator cover
try it.. nothin to lose is there? (other than yer freezer food , just run it down 1st)
hope this helps
March 3, 2007 at 5:11 pm #205731pebly
Thanks a lot, I’ll defrost it first and see how it goes. If I do end up needing a thermal fuse and evaporator cover about how much is that likely to cost ?
March 5, 2007 at 5:43 pm #205732berrys
Have you read the Samsung SRS-20 thread? Is your problem as described? On mine the evaporator fan blade was striking the build up of ice behind the front panel and making a racket until it stopped because the fan was frozen into the ice.
March 5, 2007 at 11:15 pm #205733helo_75
😯 because the thermal fuse is faulty and it doesnt defrost 😯
April 22, 2007 at 5:26 pm #205734berrys
I’ve had all the standard problems with my Samsung SRS2026CVW and I’m ready to try changing the thermal fuse, trouble is I can’t find anybody selling them for this model. Any ideas? Thanks, Simon.
April 22, 2007 at 5:35 pm #205735kwatt
KeymasterRe: Samsung – Fridge Freezer
Try here I think that’s the one’s you’re looking for, if you’re not sure email Dave on spares@ukwhitegoods.co.uk and he’ll advise. 😉
April 22, 2007 at 5:46 pm #205736berrys
Thanks for your speedy response Kwatt. I’ve had the fridge side of the F/F apart many times and this doesn’t look like anything I’ve got there, where should it go?
SimonApril 22, 2007 at 6:11 pm #205737kwatt
KeymasterThere was a photo on here the other day in one of the many threads about these machines that showed it quite well if you have a look about. I forgot which one it was, but it’s recent.
