Re: Samsung fridge freezer
ladybird wrote: Is there a cheaper way and are we killing ourselves if we only replace it once a year even if its been bleeping red for 6months?
A bit cheaper here?…
http://shop.ukwhitegoods.co.uk/index.ph … 27_492_504
As to killing yourselves…your water company would be in serious trouble if that were the case, the appliance will be connected to the mains water supply which is safe for drinking. The filter is primarily to remove any taste/odour etc from the water and ice, so you might want to ignore the filter change indicator and go by taste?
Some people do concern themselves with the trace levels of other chemicals in the water supply so if you’re really bothered you might like to check out the supply in your area?
