samsung fridge freezer
  • #30449
    excelman
    Hey can anyon advise, my fridge keeps freezing over on setting 2, on setting 1 it’s too warm. The range is 1-5. There is another sympton, on setting 1 there is water collecting in the bottom of the freezer compartment below the fridge which constantly leaks out on to the floor. I suspect the freezer is not cool enough also.
    Model RL33SBNS larder fridge freezer.
    #227237
    Re: samsung fridge freezer
    You will probably find that the drain for the defrost channel is blocked and will need to be totally defrosted and cleared,If you empty the whole appliance and turn off for 24 hrs with both doors open then restart as normal you should find it’ll start back ok.
    If the problem re occurrs then the drain is blocked and will need to be cleared.
    Bryan
    #227238
    excelman
    Hey Brian, I will do this at the weekend, I will be very pleased to have a clean fully workign fridge again so fingers crossed I suppose.
    Thanks very much and regards.
