Samsung Fridge Freezer icing up
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Samsung Fridge Freezer icing up
  • #82352
    greg spalding
    Hello, hopefully some of you lovely people can help!
    I have a samsung no frost fridge freezer model : RL33SBNS1/XEU.
    Recently, there has been a slab of ice forming in the bottom of the freezer, which eventually leaks out the door seal and melts on the kitchen floor. I have cleared the ice, but it forms again a few days later. Research has suggested the drain might be blocked, but I’m not sure where to find it! I’ve removed the drawers and the panel from the back of the freezer, but it looks like the ice is forming from a small rectangular gap below the fan. I don’t want to take it apart any further, as I’m not sure I won’t do more harm than good! Will defrosting it fully be a good start, and then see if it happens again?
    #419602
    SAMURI
    Re: Samsung Fridge Freezer icing up
    At the back of the fridge above the compressor is a rubber N/R/V ( non return valve )
    Take this off and trim it with scissors so there is a gap or throw it away as it can stick together.
    Then get someone to look after your food.
    Turn it off with the doors open for 48 hours to fully defrost.
    When you turn it back on the problem should not return.
    Bob
    #419603
    greg spalding
    Thanks Bob. I can’t seem to find what you are describing. Should I just defrost it anyway and see what happens?
    #419604
    SAMURI
    Yes just defrost it.
    Above the compressor tray is the drain from the freezer and on the end of it is a rubber non return valve.
    If you defrost it it may clear the valve if the problem returns in a few weeks you need to find the valve by feeling above the compressor tray and pull it off the drain.
    Hope this helps.
    Bob
