Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › samsung fridge freezer problem
- This topic has 7 replies, 2 voices, and was last updated 19 years, 8 months ago by
dougiex.
July 28, 2006 at 8:54 pm #19515
dougiex
ParticipantHave problem with my fridge freezer (Samsung model no RS21CSV). Its one of these American type ( side by side) with digital read out. Temperature on freezer fine, but not able to set fridge temp. At the moment it is at 16 deg and will not adjust below this (not even using power cool button). Sometimes in the morning it is down at 5 or 6 deg, but as the temp rises indoors, so does the fridge temp. Have tried pulling it away from the wall, and hoovering out the vents at the back, but to no avail. Any help would be much appreciated. Thanks in advance, Dougie.
July 28, 2006 at 10:36 pm #183469admin
KeymasterRe: samsung fridge freezer problem
hi
Hold the top rigt and top left buttons at the same time for approx 5 seconds and then tell me what you see on the display.
Hopefully you havent turned the appliance off before hand !!
Bryan
July 29, 2006 at 5:02 pm #183470dougiex
ParticipantRe: samsung fridge freezer problem
hello Bryan, after holding buttons for 5 secs all display flickered for about 2 secs and then only middle and bottom horizontal bars of 2nd digit of temp display stayed on, eventually returning to normal display.
July 29, 2006 at 6:32 pm #183471admin
then the problem has shown that it has been into defrost for mor than approx 80 mins and has failed to defrost.
get the engineer to check the defrost thermal overload and the defrost heater.
Also check the fan housing for blistering.
If the engineer requires part I can supply at r600a@hotmail.com
Bryan
August 2, 2006 at 9:39 pm #183472dougiex
Thanks for the info, but was hoping to avoid calling out an engineer. Is there any way of checking the parts mentioned?
August 3, 2006 at 3:22 am #183473admin
Supplying the parts is not a problem but unless you are compedent on checking electrical circuits then I have to advise on a engineer visit to check the defrost components for the failure.
Bryan
August 3, 2006 at 8:41 pm #183474dougiex
Hello Bryan, should be competent, I’m an electrician.
August 26, 2006 at 7:30 pm #183475dougiex
Also forget to say, the fan has been a bit noisy recently, and appliance makes some funny clunking noises.
