Samsung Fridge Freezer RS55XDGNS (RS21DPSM) Drain
Home Forums Public Support Forums Spare Parts Help Samsung Fridge Freezer RS55XDGNS (RS21DPSM) Drain
  • #90028
    Frelon
    Hi, I have just repaired my Samsung RS55XDGNS (made for French market) but equivalent to RS21DPSM with the complete repair kit. Success!!
    However the steel drain under the Defrost Heater Evaporator Element has rusted.
    I have managed to attach the drain heater element to it but fear the existing rust will get worse!!
    Can anybody please give me an indication of the part number and availability of this part.
    Many thanks
    #443322
    SAMURI
    Re: Samsung Fridge Freezer RS55XDGNS (RS21DPSM) Drain
    The part number depends on where you order it from.
    The part you require is available it comes with a new drain heater.
    The part is called a Defrost Drain Heater compleate with fixing plate.
    Try the whitgoods shop on this site.
    Bob
    #443323
    SAMURI
    The heater shown in the shop is without the fixing plate.
    If you phone on Monday they should be able to supply the heater compleate with fixing plate.
    Or you could try R600a Brian at http://www.ffrservices.co.uk
    Bob
    #443324
    Frelon
    Hi Bob, thanks for a swift reply.
    I already have a new drain heating element, it is just the drain plate I am looking for.
    Regards
    #443325
    SAMURI
    You can only buy the plate complete with heater it is not available as a separate part.
    Bob
