Samsung Fridge freezer RSA1DH leaking
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Samsung Fridge freezer RSA1DH leaking
  • #82840
    Andybell1985
    Can anyone help me please, iv noticed a puddle under my fridge/freezer iv taken the back off and this is where the water is building up, it looks like some sort of fan area, there is no writing that I can see and I’m in a panic. Thanks
    #420974
    SAMURI
    Re: Samsung Fridge freezer RSA1DH leaking
    Water will be in the tray as this is the water from when it auto defrost.
    If it is overflowing you need to check the fan is running when the compressor is running.
    It would be unusual for the tray to overflow and I would check to see if you have a leak on the water solinoid or pipe work for the water and ice dispenser
    Bob
    #420975
    Andybell1985
    Hi, iv watched it for half an hour and the fan is working, iv noticed there is a small gap on the seal of the freezer door, could this be an issue iv had for a while that’s finally overflowed?
    #420976
    SAMURI
    Yes if the door seal is not sealing on the freezer then it would ice up too much in the freezer.
    Then when it defrost it could overflow the drain tray.
    Bob
    #420977
    Andybell1985
    That’s solved that then thank you very much for your help
