samsung fridge freezer sr-s2026cvw
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum samsung fridge freezer sr-s2026cvw
  • #75564
    trekkie1701e
    i have just acquired this model second hand, the freezer holds constant at the temp i set… -16degrees but the fridge temp is fluctuating between 2 degrees and 13 & 14 degrees, i would appreciate any insight as to why this may be…
    many thanks in advance
    #395480
    Specialist01269
    Re: samsung fridge freezer sr-s2026cvw
    Hi: I don’t touch the refrigeration side myself, but you’d get a quicker response if you asked your question in the fridge / freezer section.
    #395481
    trekkie1701e
    sorry, thought i was in fridge/freezer section
    #395482
    Specialist01269
    No problem: Management have moved it for you.
