Hi, I normally avoid these but a drum not turning fault was worth a look.
DV90M50003X/EU belt ok but motor not going no sound off of it doesnt start even with a push of the drum, I was
going to get a capacitor but thought it might be something more sinister, any aideas welcomed
ok if the motor was energising the freel of the drum when you push it would change. even if the cap was not in circuit i would expect the run winding to energise which would make the drum feel heavier or light to push
you would need to take the side off to check motor and on samsung (did one yeaterday) you have to remove the front to remove side
