Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Samsung J1253 washing machine
- This topic has 12 replies, 6 voices, and was last updated 17 years, 8 months ago by
akkie.
July 31, 2008 at 3:46 pm #38444
akkie
ParticipantJust came from work and my wife has said the washing machine wouldnt drain out the water after it completed its cycle any ideas what could be wrong? she also says theres a kinda rattling noise from down the bottom of the machine where the filter is?
any help would be great folks
thanks in advance
akkie
EDIT: well after close inspection the wife had indeed took out and cleaned the filter but the little fly wheel object behind it was sitting free as a bird and she said well I screwed it back on but after checking that it had no threads i pushed it back into place and bon voyage awau she went drained fine again…thanks anyway.
July 31, 2008 at 6:27 pm #258879Washman
ParticipantRe: Samsung J1253 washing machine
Pump needs replacing , impellor should not be loose and will fall off again.
An E-mail to spares@ukwhitegoods.co.uk with model details will get you a new pump.
MikeAugust 1, 2008 at 10:45 am #258880akkie
your right how much does it cost man and is it quite easy to change the pump myself? its a Samsung J1253 (V/S/C) model email on its way also.
August 1, 2008 at 7:42 pm #258881akkie
why is noone replying to me does noone use the site at the weekend or what?
August 1, 2008 at 11:46 pm #258882Penguin45
Contrary to popular opinion, most engineers do try and have some sort of social life……….
The pump motor indicated in your other post will fit and is retained by three screws at the back. Tip the machine back to a good stable angle for access.
Unplug first.
Penguin45.August 2, 2008 at 9:05 am #258883gegsy
Penguin45 wrote:Contrary to popular opinion, most engineers do try and have some sort of social life………..
😯 When did this happen 😆
August 6, 2008 at 8:32 pm #258884akkie
ok guys new pump fitted and thanks for the help..now trying a rince and spin program to clear out the old smelly water will report back my findings…if all goes well I will return with my findings and thanks hopefully..wish me well.
August 6, 2008 at 9:48 pm #258885akkie
well would like to thank the guys who helped me it worked fine….thanks to you all..this website rocks
August 12, 2008 at 5:46 pm #258886akkie
ok guys little problem the small black discharge hose for emptying the machine which is located next too the filter and adjoins onto the pump has a small hole (must have happened when I took the machine out on a trolley) can they be bought? on one end its like a sparkplug cover on a car the other end can be seen marked as number 1 on the pictures ive included. samsung dont have a clue what im on about, I can take an actual pic of the hose with dimention sizes once the washing finished washing.
took these pics from the front cover that lets you into the filter
http://www.tartanrascals.co.uk/discharge_hose.jpg
http://www.tartanrascals.co.uk/details.jpg
thanks in advanceakkie
August 13, 2008 at 8:51 pm #258887Penguin45
Might be best to email spares@ukwhitegoods.co.uk direct on this – most us have no access to Samsung parts listings.
That said, you could just substitute a length of rubber hose and a suitable stopper for rather fewer pennies than Samsung will require.
August 13, 2008 at 9:08 pm #258888helo_75
Participantor just block it off at the pump end…..
August 14, 2008 at 2:57 pm #258889akkie
You know I thought about that just block it off but then samsung emailed me to say they found the part for £4.75p plus believe it or not £5.00 delivery can you adam and eve that…are they from sherwood forrest samsung? or is it being sent in a teachest?
August 15, 2008 at 11:38 am #258890cockney steve
Penguin and Helo have both given good suggestions…so I’ll add one…If the hole is near the end, just cut that bit off and refit the stopper.
If it’s further in, cut it and push in a “bridge” (a piece of small brass tube (model shop? ) or vinyl tube -same source, or car windscreen-washer tubing-may do the trick.
It’s only a drain and has very little pressure on it,- though you don’t think that when tou pull the filter before draining!
