Samsung j1453s
Viewing 15 posts - 1 through 15 (of 22 total)
  • #46951
    have been to this machine and no matter what i do i cant stop the soap draw leaking
    has anyone had this problem on this machine or the like and is there a simple cure
    am trying to souce a complete draw body but hitting brick walls a mo
    thanks
    philfish
    Re: Samsung j1453s
    Is the water pressure to high? just a thought otherwise would say its a new dispenser 😥
    phil
    #291593
    Re: Samsung j1453s
    tried turning water down still leaks
    thanks
    andy2
    Re: Samsung j1453s
    Assume you have checked if the machine is level and not leaning forward?
    You could try packing it up at the front to run the water towards the rear of the dispenser (assuming the outlet is at the back).
    Also is the SD hose completely clear? Some machines have a “u” bend shape hose and can become blocked or restricted with undissolved powder
    Andy
    #291595
    robbo1973
    Re: Samsung j1453s
    if you take the hose disp hose off from the tub by taking off door seal from front face there is a little flap which can either stick a bit or i have had items partially or totally stuck behind it causing soap drawer to leak.
    cheers chris
    #291596
    robbra
    Re: Samsung j1453s
    I had one, tried all the wrinkles to fix it over a couple of days. In the end fitted a new soap drawer top and cured it immediately so having had a couple more I just do that.
    Rob
    #291597
    LJDomestics
    Re: Samsung j1453s
    is the spray nozzles inside the dispenser box all black and gunged up? possibly squirting the inlet of water into a direction that allows it to escape?
    #291598
    LJDomestics
    Re: Samsung j1453s
    a possible clue as to they are clogged is remove the lid of machine and look around the seam of the dispenser outer ( box ) if u see dried soap powder around the seam assume a blockage.
    A good flush out by removing and cleaning with boiled water normally works for me.
    #291599
    timdowning
    Re: Samsung j1453s
    I agree with Rob.
    Change the dispenser upper assy. When I did in-guarantee work for Samsung this was the only way to sort it.
    I did loads of pratting about, at first, with pressure, machine levels & cleaning none of it worked with these Samsung machines.
    #291600
    robbra
    Re: Samsung j1453s
    Thanks Tim,
    Nice to have backup.
    Not worth the pratting about cleaning ‘cos it don’t work
    Rob 😆
    #291601
    LJDomestics
    Re: Samsung j1453s
    robbra wrote:Thanks Tim,
    Rob 😆
    pratting about?
    i cal it “service”
    oh well. 8)
    #291602
    robbra
    Re: Samsung j1453s
    Well LJ,
    If it doesn’t work, as I have found on this model a few times, then it isn’t service it’s a waste of mine and the customers time so it is a new soap dispenser top every time. It’s down to experience on this machine ,which is what Dave was after in the first place. Perhaps you know otherwise.
    Rob
    #291603
    timdowning
    Re: Samsung j1453s
    LJ you must stop being so sensitive.
    My ‘pratting about’ comment was in regards to these Samsung machines, not to all makes and models.
    I find cleaning, levelling, poking, adjusting, jabbing, staring & SERVICING does work on many other makes.
    #291604
    Re: Samsung j1453s
    timdowning wrote:I find cleaning, levelling, poking, adjusting, jabbing, staring & SERVICING does work on many other makes.
    Often, I just walk in the door and it fixes itself. 😆
    Mike.
    #291605
    robbra
    Re: Samsung j1453s
    Mike.
    Big ‘ed 😆
    Can I borrow you for an outer tub change on a San Georgio?
    R
