samsung jerky drum
  • #93516
    penfold58
    hi all if any one can help i own a samsung ecobubble mod wf1124xac and 3 years ago i had to replace the main pcb board for this problem would start to wash but then have problem trying to move drum one way or other it is the mod with drive belt and brushless motor it has now started to do this again with the replacement pcb board ive since put two new capasitors in this board the 420uf 250v ones as i read some where it was one of those gone bad but i still have the same problem what id like to no is this as this is a com problem with this mod and pcb board samsung part number dc92-00969a y625 does any one no what component on the pcb board that breaks down to do this fault apart from the two big capasitors that ive replace
    #454639
    Lawrence
    Re: samsung jerky drum
    what programmer do you have it on ?
