Samsung M1714
  • #5677
    Brains
    Have one of these in for repair with a blown 6A fuse. No obvious shorts. Does anyone have a circuit diagram, or a service manual I could borrow or even get a photocopy.
    Or, better still any one have any ideas of the fault? Following the wiring suggests a possible problem with the controller.
    Thanks for any help.
    #113033
    Dave_Conway
    Re: Samsung M1714
    Brains, could you get the full model number from the rating plate, there’s a whole load of different versions.
    The liklehood is they’re all the same, but just in case 😉
    #113034
    Brains
    Re: Samsung M1714
    Thanks for the reply. The only other number I can find is:
    7JB R2 02375F
    Regards
    Mike
    #113035
    Dave_Conway
    Re: Samsung M1714
    No idea what those numbers are 😕
    Anyway, I picked a couple at random and they all look to be the same so there’s some info on the way that may be usefull 😉
    HTH
    #113036
    Brains
    Re: Samsung M1714
    Again – many thanks. When I eventually find the fault, I’ll post on one of the forums. Maybe it will someone else.
    Regards
    Mike
