HI all
Please help,
I have Samsung model RS21DGRS which is tripping the electric circuit as soon as I plug it in mains. I changed the Defrost heater but the problem is still there what do you suggest i should do now
many thanks
There are 2 defrost heaters, but changing them on the basis that they *might* be faulty is obviously a false economy as you have found out after changing a part and it not being the cause. Unless you have a megger and know how to use it, I’d suggest getting an engineer out to it or the alternative is to continue playing parts roulette and you might spend a huge amount and still not find the problem. There are many parts on this appliance that could potentially cause it to trip the electrics.
