samsung oven
  • #76887
    dopper
    its a bf641fst clock was dead as was hole cooker so fitted a new stat behind panel and power comes on and clock works, but when oven or grill turned on fan works but no heat from ant elements also clock flashing pre, anyone advise
    dop
    #400101
    Re: samsung oven
    Pre is pre heat, Is it set correctly and have you checked the rear toc’s ?
    Bryan
    #400102
    dopper
    Re: samsung oven
    rear stat was testing ok going back to try and set clock will check rear stat again should it be open or closed ?
    #400103
    stevebunyan
    Re: samsung oven
    Have you checked main stat, just thinking out load, but what caused the overheat toc to go open circuit?
    Clarence William Appliance Repair
    http://www.clarence-william.co.uk
    #400104
    Re: samsung oven
    Electronic not standard stat.
    Bryan
    #400105
    dopper
    Re: samsung oven
    not sure what made it go and its not a standard stat bit of a pain now
