samsung oven
  • #80290
    clockworkone
    Bf641fst.Type 01.Does anyone have any tech on these.Only thing that works on this one is oven light,no display showing.Outer grill element o/c and fan oven element tags badly burnt.Power to board but not from it.Need info on stats and cavity sensors (o/c or closed)Looks a very over complicated single oven.Paul
    #412353
    Re: samsung oven
    had one of these to do a while ago cant remember model but i thought board had gone. ended up there was a mod and i had to change board and loom
    on yours look at the red socket. has it got 3 pins or more(poss 9)
    if its got 3 your in the same boat new board has 9 so complete loom required to fit
    have also got ntc so just measured it and got 1.2 meg ohms this shop not heated now so you can get an idea of the temp (may not be same model but board looks the same )
    clockworkone
    Re: samsung oven
    Thank you Dave for reply.I believe there is more than 3 pins in red plug.I think the version that needed new loom etc was type00.That is only version with footnote about change in connect website.This one has 01 in box after mod no on name plate, so hoping it is updated version.Thanks again.Paul
