Samsung P1253
  • #39482
    Justchillin
    When on spin cycle the machine counts down from 10 mins remaing to 9 mins then reverts to 10 mins. Drum revolves but does not go into full spin.
    Can hear relay on pcb clicking when the times change.
    Suspect PCB.
    Anybody with any experience of this machine/fault.
    If its PCB would you agree that its BER?
    Cheers
    Steve
    #262566
    Dales-Electronic
    Re: Samsung P1253
    Yep its the PCB if you check the transformer on the board and its red then it will need replacing to the later board.
    #262567
    boselecta
    Just an idea but I have been to loads of these, they have a very sensitive out of balance load and do exactly this with an out of balance load.
    Redistribute the load, try with a full load.
    Have you tried spinning it empty.
