Samsung P1253
  • #56418
    spimps
    Blown triac on board 2which I can’t get any numbers of,anyone recognise who could help as I hope to just replace the triac.
    Pump burnt out and took triac with,everything else is OK barr emptying.
    It’s the no 3 triac on the board,one next door to it is marked M2LZ47 6-v,down in the bottom rh corner.
    Cheers
    #327307
    spimps
    Re: Samsung P1253
    Anyone please ?
    #327308
    A1_Domestics
    Re: Samsung P1253
    I got one in the workshop. Give me till tonight.
    #327309
    Re: Samsung P1253
    Can’t get the full size image to load.
    Mike.
    #327310
    spimps
    Re: Samsung P1253
    Seems to be a problem on imageshack,try later.
    #327311
    spimps
    Re: Samsung P1253
    Image now loading
    #327312
    Re: Samsung P1253
    Should think it’ll be the same as one next door. Triacs all do the same job AFAIK. If the package is same then legs should be in same order. In fact there’s some print on the board which you can probably still read once you clean off the burn. This should confirm leg position. Nothing to lose.
    Ah, slight problem. That number M2LZ47 seems to be a bit foreign. Googling no. brings up datasheets but not much that seem to relate to this component. Still, if the print on the board says e.g. gt / Mt1 / Mt2 or gt / A / C or some such then it probably is a triac and as long as you get one same size and package you should be OK. RS or Farnell will have PDF’s showing what leg is what on everything they sell.
    Mike.
    #327313
    A1_Domestics
    Re: Samsung P1253
    The board I have looks almost the same as yours, but it has a transformer (as far as I can tell), next to the heatsink. However, the triac has the same numbers as already mentioned. T2, T4 & T5 have m1L43 5.k printed on them.
    Unfortunatly I can’t upload a photo ATM for technical reasons.
    #327314
    spimps
    Re: Samsung P1253
    Thanks for your help chaps,much appreciated.
    BG
    #327315
    spimps
    Re: Samsung P1253
    Found via the data sheet for this triac a suitable alternative.
    #327316
    Re: Samsung P1253
    Can you post up the number? Could be of use to one of us one day. 😉
    Mike.
    #327317
    spimps
    Re: Samsung P153
    Is a LM317T,did find the origional but minimum order quantity was 400, 8O.
    BG
