Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Samsung P1253 Problem
- This topic has 13 replies, 4 voices, and was last updated 18 years, 12 months ago by
kirkie.
April 14, 2007 at 5:38 pm #26600
kirkie
ParticipantI have a problem with the above machine. It was showing an Error Message 5E and making quite a noise, so I checked the debris filter. When I removed this I saw a little small impeller type thing and noticed that this wasn’t attached and presumed this was what the noise was. This easily pushed back on, but ever time I put the machine on spin it makes the noise again and the impeller doesn’t stay on. Any ideas?
April 14, 2007 at 5:48 pm #210750kirkie
ParticipantApril 14, 2007 at 5:58 pm #210751Penguin45
ParticipantRe: Samsung P1253 Problem
Or this:
http://www.ukwhitegoods.co.uk/modules.p … cts_id=651
Or, if you can wield a screwdriver with aplomb:
http://www.ukwhitegoods.co.uk/modules.p … cts_id=165Once the impellor comes off, it will not stay back on, so replacement is your only option.
Power off, if you’re going to do this yourself.
Penguin45.April 14, 2007 at 6:01 pm #210752kirkie
Penguin45 wrote:Or this:
Penguin45.Thanks for the quick response. Is it easy to do or should I be looking for a good engineer in the Hull area…. 😯
April 14, 2007 at 6:04 pm #210753kirkie
Sods law I think it is out of warranty as it was bought January 2006…. 😥
April 14, 2007 at 6:21 pm #210754Penguin45
Fairly straightforward – if you tip the machine back, you can get it from underneath. Power off, of course.
Guarantee may not have been stood in these circumstances anyway – it’s invariably foreign object damage which knocks the impellor off. 5p’s are excellent at it 😀 .
April 14, 2007 at 6:49 pm #210755Washman
Check your user manual Samsung washing machines should have a two year guarrantee . Phone Samsung with model and serial numbers both found on rear of machine. And have proof of purchase ie:invoice or delivery note handy. Just tell them it will not drain and is noisy .
Mike
April 15, 2007 at 2:25 pm #210756Mac1982
The unit is under a 2 year warranty from samsung
Any unit purchased prior to 01.05.2006 has this warranty. Anything after that is a 12 month warranty
April 15, 2007 at 4:35 pm #210757kirkie
Mac1982 wrote:The unit is under a 2 year warranty from samsung
Thanks for that. This has just been confirmed by Samsung and I get an engineer on Wednesday.
April 16, 2007 at 12:46 pm #210758Mac1982
Glad to hear.
Did they tell you that you wld need your receipt/ del note??? Cos its a requirement by the engineers.
April 17, 2007 at 5:13 pm #210759kirkie
I’m all sorted now. Engineer has been fixed the problem I thought it was. Still under warranty and I didn’t have to have proof of purchase..
April 18, 2007 at 6:09 pm #210760Mac1982
Glad to hear.
In case you werent aware, the repair on the unit carries a 3 month warranty with is separate from the manufacturing warranty itself.
April 18, 2007 at 6:30 pm #210761kirkie
Mac1982 wrote:Glad to hear.
Thanks for that…
April 18, 2007 at 6:58 pm #210762Mac1982
No probs mate 😉
