samsung pump
  • #47719
    wilf
    P1253 washer needs a pump which is an askoll a standard fits and works ok but the original had a sealed coil what is the purpose of this and is is of any significance? I would have changed the coils but the new askoll pump has been redesigned and would not fit.
    just curious wilf
    p.s. genuine samsung pump very expensive
    #294358
    robbra
    Re: samsung pump
    The Samsung pump had a toc fitted as standard. They were either chinese where the impellor broke away or Brazillian copies of Askoll and were fitted with a toc because Samsung knew they were fitting junk. I have fitted both Askoll and Plaset with no problems.
    Rob
    #294359
    deltra
    Re: samsung pump
    same as rob, no problems with askoll or plaset 8)
    #294360
    wilf
    Re: samsung pump
    thanks chaps! like I said just curious
    wilf
    #294361
    Re: samsung pump
    Sort of related to this question, why don’t modern pumps have an earth connection? Are they classed as double insulated?
    Mike.
    #294362
    robbra
    Re: samsung pump
    Must be Mike, nothing to connect earth to.
