Got the above samsung comes up 13E
Originally tripped rcd after going pop during cycle.
Insulation sound but now comes up with error code as soon as it is switched on
Any idea’s on this error code would be a great help
Thanks Ian
Hi 13e is a communication error between the main and sub PCB’s I’ve seen the wires get chaffed inbetween the 2 PCB’s causing it to trip the RCD I would check there 1st.
Good luck.
