Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › samsung q1433s 1E
- This topic has 9 replies, 3 voices, and was last updated 17 years, 6 months ago by
dave1379.
September 26, 2008 at 6:59 am #39764
dave1379
Participanthi i have a 1e flashing code on my samsung washer ,this code is not in the manual so i have checked the front and rear filters for blockages ,after pulling the emergency door lock pull a few times the code stopped only to come back after approx 15 mins. thanks for any help recieved
daveSeptember 26, 2008 at 2:52 pm #263503iadom
ModeratorRe: samsung q1433s 1E
E1 relates to fill problems. Have you checked for kinked fill hoses or poor water pressure. Remove the fill hoses and run them into a bucket to see if you have a decent flow of water.
September 26, 2008 at 4:32 pm #263504dave1379
ParticipantRe: samsung q1433s 1E
hi thanks for reply, i have checked main hose to washer and have good pressure,i have then checked the 3 way pressure valve as best as i can and the 3 pipes that come from here and all seem clear.iam a little comfused why if i pull the emergency door realese a couple of times the washer works for about 15 mins.
September 26, 2008 at 6:44 pm #263505iadom
Samsung is not my forte, some of the lads are away for the weekend at a meeting. If you don’t get any other replies by Sunday then by all means give this thread a bump. 🙂
September 26, 2008 at 6:44 pm #263506helo_75
Participantthen maybe it syphoning? check the height of the drain hose!
September 26, 2008 at 6:58 pm #263507iadom
DOH, now why didn’t I think to mention that, a senior moment. 😳 😀
September 26, 2008 at 8:53 pm #263508dave1379
i will check thanks but why would it play up now after several years ,will try anyway thanks
September 26, 2008 at 9:37 pm #263509iadom
Your outlet pipe should discharge into a standpipe that is at least 20″ above floor level or into a proper sink waste outlet. It should go down into this pipe no more than 5 or 6 inches. ( Sorry don’t do metric)
If it does discharge into a standpipe, have you moved the machine for any reason recently? If you have you may have pushed the outlet pipe down into the standpipe so that it is lower than the normal water level in the machine. This would cause syphoning.
A quick ,simple test. If you can place the end of your outlet pipe over the sink and try the machine, that would eliminate syphoning as a possible cause of the problem.
September 27, 2008 at 4:29 pm #263510dave1379
ok update ,checked drainage which was ok so had a luck inside again to check wires and anything loose and by chance every time i touched a 3 pin plug which went to a round brown type thing on top off my washer the door would lock bringing on the 1e fault code, so tightend pins on plug and tested ,all ok after 2 washers so touch wood lol
thanks for all help given and lets hope its fixedOctober 19, 2008 at 10:28 am #263511dave1379
hi my washer is still doing the same grrr, the brown thing i refer to has dl-s14 on the side and has a vac pipe going from it to the bottom of the drum , i have replaced the 3 wires and connections and all good for a couple of washers , i caint see how this can be related to my fault but when i get the 1 and flashing E on my display if i fiddle with this part it clears the fault code.any help would be good before i lose my mind 😕
