Samsung Q1435V and 8E error
Home Forums Public Support Forums International Forums European Appliance Forum Samsung Q1435V and 8E error
  • #32618
    Jykke
    Hello and thanks for this forum!
    Can any one help me to diagnose 8E error in my washing machine.
    The problem is that motor won’t run. Motor just “rattles” and does not do full turns. Multimeter says 4,2ohms between all three wires. So I think motor is OK.
    Could this be PCB failure? Any idea how to fix PCB?
    Or is new PCB only solution?
    #235784
    Washman
    Re: Samsung Q1435V and 8E error
    8E” is over current error , if motor not turning most likely PCB fault.
    Mike
    #235785
    Nutty
    You are unable to fix a PCB board so a new one is the only option there
    #235786
    Jykke
    Thanks for help. PCB was broken. With new PCB machine is running good now. 😀
    I found new PCB for 01435VGW1/XEE from http://www.elfa.se/
    Part number: 96-102-18
    #235787
    ziam
    Hello, I am after this part also, do you have a direct link as I cannot find it?
    #235788
    ilektroepiskevi
    Yes usually most times this is a pcb fault.Sometimes the pcb can be repaired but most times need to buy a new one. Samsung here in my country don’t have a good service dealership 😥 https://ilektroepvi.gr/????????-??????????/
    Mod edit;
    I have edited your advertising link, if you wish to advertise on this site you need to contact admin@ukwhitegoods.co.uk You are more than welcome to use the forums 🙂
    Don
