SAMSUNG Q1636SGS MOTOR ACTION
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries SAMSUNG Q1636SGS MOTOR ACTION
  • #19204
    mbdas
    Afternoon 🙂
    Ive got the above machine with no motor action it just Buzzs and flashes E8 Its sounds like a new motor or module or taco just woundering if anyone has had a problem with these
    Mark 🙂
    #182159
    timdowning
    Re: SAMSUNG Q1636SGS MOTOR ACTION
    Does the motor judder before it aborts to error message? If it does I’ve had this a few times, Main PCB at fault.
    #182160
    Washman
    Main PCB fault have changed a few , Motor judder is main symptom.
    There are no visable signs of a fault when you look at PCB.
    Change PCB and machine should work OK
    Mike
    #182161
    Bill
    I have not been to one of these problems for a while!
    Bill Ellis :scot:
    #182162
    mbdas
    Hi 🙂
    Yes the motor does just judder one way and then aborts with E8 up
    I have continuity through the motor windings but not sure what the resistance values are ❓ I have 4.6k through the hall sensor thingy ❓
    #182163
    Washman
    New PCB will fix problem. Motor should be OK
    normally only PCB required
    Mike
    #182164
    mbdas
    Thanks Guys I let you know what happens 🙂
    #182165
    mbdas
    Spot on guys 🙂
    Fitted module yesterday worked a treat 😀 😀
    Mark
