Samsung refrigeration door seals
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Samsung refrigeration door seals
  • #22264
    cab
    Hi, anyone had problems with the seals on Samsung f/f. Have an RS21 the freezer isnt sealing properly, no suction on door, dead easy to open, and frost forming inside, ordered and tried to fit new seal, the new one was worse than the old, tried heating and forming the seal, no joy. any help would be great.
    cab
    #194231
    Re: Samsung refrigeration door seals
    r600a said that you can get distortion at the top of the door and you need to pack the seal forward to make the seal.
    cab
    If you pack the seal surely it wont be flush and would be visible.
    cab
    #194233
    ncas
    THERE IS A SPACER BEHIND BOTTOM HINGE WHICH CAN BE REMOVED TO HELP ALSO YOU CAN TURN SEAL UPSIDE DOWN I.E. FIT AND LEAVE RETURN AND PUT UPSIDE DOWN SOUNDS DAFT BUT IT OFTEN WORKS WITH THE HELP OF A HAIRDRIER TO ADJUST
