samsung RL 38SCPS
  • #81057
    spencer123
    HI my fridge compartment isnt cooling any ideas waht to check many thanks 😥
    #415226
    SAMURI
    Re: samsung RL 38SCPS
    It may not have defrosted itself in the freezer Empty the fridge and freezer and turn it off for 48 hours with the doors open.
    When you turn it back on after about 2 to 4 hours it should be back to normal.
    If the problem returns after a couple of weeks you have a problem with the auto defrost system.
    You can also check to see if the fridge door is turning the light off in the fridge as this also turns on the fan.
    Bob
    #415227
    spencer123
    thanks for your help will try this.
