samsung rl33bns f/f
  • #33973
    msappliance
    hi,
    the fridge is not cooling freezer is on the 5 light display the last 4 lights are flashing together can anyone help?,thanks/
    #240732
    robbo1973
    Re: samsung rl33bns f/f
    take off the freezer cover inside and you will find the baffle top left is frozen up. clear ice from around and remove rubber gasket this will cure problem 5 min job.
    cheers chris.
    #240733
    Evap cover vent frozen shut.
    Defrost the air channels upto the fridge.
    Open up and remover the rubber square seal and it should be ok.
    Bryan
    #240734
    msappliance
    thanks a lot
    #240735
    msappliance
    ok i managed to get back to appliance there is no ice build up and rubber has been already removed. when you switch appliance on the flap turns a few times, closes and then lights flash any more help please im getting desperate. sensor fault ?
    #240736
    Evaperator cover will probably need to be replaced as this is the fault showing.
    Bryan
