Re: Samsung RL33BNS1 Fridge Freezer Problem
4 lights flashuing (not left one)=baffle motor faulty – Like has been said defrost the whole unit ideally leave doors open and off for 2 days it seems overkill but you cant see the ice….
The baffle motor is the flap that opens and closes to let cold air into the fridge. Leaving the door open draws in warm air which is full of moisture this then freezes.
After defrost will be fine Stollydriver is correct 😀
