Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Samsung RL33SB Noisy then stopped working
- This topic has 4 replies, 1 voice, and was last updated 16 years, 3 months ago by
Tom333.
January 8, 2010 at 6:33 pm #51488
Tom333
ParticipantHi everyone,
I checked the forums and couldn’t find this particular problem. My Samsung RL33SBSW1/XEU (serial number: 4ABX600100X) was making a lot of noise and it sounded like the fan was hitting something but I’m not sure. Anyway I switched it off then on and the noise stopped but the fridge and freezer wouldn’t cool any more.I left it off for 3 days and switched it back on but it makes the odd click noise and a faint air circulating type noise and some air is gently coming through the vents in the freezer and the freezer. This stops when I press the fridge door close button.
I’d be really grateful for any advice.
Here’s a little extra information. I’ve had the fridge/freezer for 6 years. It has a 5 light display at the top and the lights are operating normally with 3 lit showing the temperature setting. There is no LCD display on this model. Thanks
January 9, 2010 at 5:47 pm #308248Tom333
ParticipantRe: Samsung RL33SB Noisy then stopped working
I managed to download a service manual and it helped me to get the panel off at the back of the freezer compartment.
The fan is spinning away with no problems and to the left of the fan is a flap that was turning.
January 9, 2010 at 6:28 pm #308249Tom333
I found this webpage that helps people that know nothing like myself.
http://www.repairclinic.com/Refrigerato … leshootingIf I can hear clicks then thats probably the thermostat working. Is this right
Any advice from a professional would be very much appreciated. Thanks.
January 15, 2010 at 5:13 pm #308250Tom333
I’ve found out a little more information. When I switch the fridge freezer on there is a loud click followed by a faint hum coming from the compressor. Then just a few seconds later there is another loud click and the hum stops. This keeps happening over and over if I leave the fridge on. Its click then compressor hum for a fewseconds then click and no hum then click then hum and so on over and over.
I managed to follow instructions on a web page to test the compressor overload protector and it seems to be fine (0 ohms). I also tested the compressor motor which again showed 0 ohms. Between two the left and right terminals and the common terminal I got readings of 15 and 16 whatever that means. I’m a complete novice though and my multimeter is a cheap one so may not be reliable.
The compressor relay is solid state so I couldn’t test it.
I don’t know what the original noise was but maybe it was the fan hitting ice (hopefully and nothing more serious).
When somebody gets a moment I would be very grateful for some advice as to the most likely cause based on your experience. Thank you.
January 16, 2010 at 2:01 am #308251Tom333
I ran the compressor off a test cord with the overload protection disconnected. I could try changing the relay but from what I’ve read elsewhere it is likely to be a compressor fault. http://www.ukwhitegoods.co.uk/modules.p … lay+click*
I’d still like the opinion of someone experienced though. I’ve just being following step by step instructions from websites. I don’t actually know anything. Thanks 😀
