Samsung RL33SBNS – error code
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Samsung RL33SBNS – error code
  • #61350
    MattyD
    My Samsung RL33SBNS is flashing the four outer lights on and off and wont seem to switch on – presume this is some kind of error code – can anyone translate it?
    It was making some noise and there was ice in the freezer, so I defrosted it thoroughly and switched it back on and it wouldnt start, just the flashing lights.
    I checked all the connections internally in case there was a sensor loose or something – all seem ok visiyally. It has suffered from frosting up over the last three years, but usually a good defrost sorts it all out.
    Any advice gratefully received.
    Matt
    #345793
    MattyD
    Re: Samsung RL33SBNS – error code
    I found a manual online and it indicates that this combination of flashing lights indicate that it’s a freezer temp sensor malfunction.
    Relatively cheap to replace, so I will try that and see if normal service is resumed.
    Matt
