Samsung RL33SBNS1/XEU
  • #66928
    davecat
    Hi, Fridge freezer has packed in on me. The unit has power, fridge light is on, the temperature indicator is on but it’s not cooling or freezing. when power is switched I can hear the ‘clicks’ but the unit is then silent. Could it be the compressor, or something else perhaps? Compressor type is ZBS1115CY. Any help would be appreciated.
    #365667
    Re: Samsung RL33SBNS1/XEU
    Does it run at all if left switched on ? or if you turn it off for 30 mins when you turn it back on how long is it before you hear the clicks and where from ?
    Bryan
    #365668
    davecat
    No not at all, I will unplug it now and try in 30 minutes or so. The clicks are from the top, where the lights are, it’s that sort of ‘normal’ tick sound happens about 2 seconds after powering up, then a louder click sound. I’m guessing these are normal.
    #365669
    davecat
    OK, Plugged back in… The first ‘tick’ about 2 seconds, the ‘click’ about 6 seconds.
    #365670
    davecat
    Just turned it off / on, I put my ear against the unit – after the click I can hear something, It sounds like it is working then about 45 seconds later the click occurs again and the unit is silent.
    #365671
    I take it that none of the lights on the top are flashing ?.
    If that is the case then I would if your competent to do so check for power at the compressor..
    Bryan
    #365672
    davecat
    No flashing lights. Can’t detect any voltage @ compressor, I got a 16v reading from the transformer that feeds the pcb. There is also a capacitor, from which I also couldn’t detect voltage.
    #365673
    How long has it not been working ?
    #365674
    davecat
    Since yesterday.
    #365675
    Has it totally defrosted ?. If so then start looking at the pcb.
    Bryan
