Samsung RL34LGMG
  • #82981
    don
    Don’t see much Samsung refrigeration to know…….
    This one has slight frosting in each corner of the top freezer bin, the fridge is not getting cold and there is condensation on salad bin and water underneath it as well.
    All sensible offers of help greatly appreciated 🙂
    Don
    #421335
    SAMURI
    Re: Samsung RL34LGMG
    A good chance it is frozen up and iced up the fan motor.
    The fault will most likely be the defrost drain rubber NRV above the compressor stuck together or blocked so the defrost water cannot run away.
    You will have to fully defrost it to make sure the drain is clear and trim the NRV so it cannot stick together but still reduses the air into the freezer
    Bob
    #421336
    don
    Thanks Bob 😀 I’ll pass the info on to our engineer.
    Don
