Hello,
I my Samsung (RL39THCSW) compressor will not start.
When turned on compressor make a “mmmm” noise trying to start and then i hear a “Click” all cuts outs.
Checked relay and there’s continuity.
Checked Compressor getting 21ohms, 26 ohms and 47ohms seem high but not sure.
Tried to check thermistor got 4 wires 2 yellow,1 brown, 1 black coming from back going to temp control board not sure which ones to test. So tested all can’t get any continuity.
Could the thermistor be causing this issue??
Does anyone of a wiring diagram for ths model??
Thanks Nade
