This larder fridge keeps cutting in and out. If it’s switched off for a couple of mins it will come on as normal, then cut out 1 min 50 secs- everything off, you hear the relay click on the board and it cuts out!
can anyone forward any test information please?
tested socket,mains lead,can’t see anything suspect on board.
I’ve tested the 3.5 and 0.33uf capacitors on the top by board and they’re fine.
cheers
