SAMSUNG RRS21DGRS Tripping rcd
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum SAMSUNG RRS21DGRS Tripping rcd
  • #50136
    SHEEPYBUTCH
    Hi my Samsung RS21DGRS is tripping my RCD all the time. I have stripped out the back of the fridge compartment to get at the evaporator and defrost heater.This connects electrically by three small blocks, when carring out checks if i leave the top one disconnected and apply mains power the unit will start up and run after about 20sec delay.
    The display panel is blank during this start up time except for a small 1 fig in the top right of the fridge display, after 20 ish sec the unit starts and no fault codes are displayed when you try the diagnostic check.
    I guess this is the Defrost Sensor that i have dissconected (red & black cables sensor wrapped in white foan tie wrapped to bottom right side of evaporator and defrost heater
    Could someone please help re repair , do i replace the sensor only or is there further check i need to do, or is it the evaporator and defrost heater that need replacing as advised in other posts on this forum
    many thanks kev.
    #303733
    spimps
    Re: SAMSUNG RRS21DGRS Tripping rcd
    This thread should be of interest.
    You need a meggar to check for this fault to identify the culprit,probably time for an engineer.
    #303734
    helo_75
    id be ringing samsung for some ‘advise’
