Samsung RS 20CCSV
  • #47233
    Steven
    Can anyone confirm that the 2 yellow sensors on this model are exactly same part. (one clip on evaporator and one on the cover sensor) Both in Freezer? DA3200024C
    Steven
    #292772
    Re: Samsung RS 20CCSV
    Is that an SRS20CCSV?
    There’s hundreds of the damn things and you need the full and correct model or you’re scuppered.
    I respectfully hate these things. 😉
    Steven
    Just RS20CCSV Single evaporator unit in freezer for both.
    Fault code on the freezer digit 8 lower right illuminated which states evap sensor.
    Have already replaced it, so assuming its faulty one? as it freezing down fine, temp recorded -18 on display but just blocked solid so fridge is warm.
    Defrost heaters seem ok, however tried getting into forced defrost just would not do it. Never seem to get these things into a test mode 😳
