Samsung rs 21 condensation
  • #37995
    msappliance
    Has anyone had a condensation build up in the fridge behind the bottom 2 salad trays causing it to leak on the floor?
    If so how do i solve it?
    Thanks.
    #257357
    gegsy
    Re: Samsung rs 21 condensation
    Probably in need of the modified backplate and sensor.
    Maybe also a split water reservoir (if fitted) due to above problem.
    lerch
    ASSY-COVER EVAP REF KIT DA97-05290Q
    ASSY-COVER EVAP REF KIT DA97-05290E (With CSZ)
    SENSOR TEMP-DEFROST-SENSOR DA32-00006U
    THERMO FUSE ASSY DA47-00095E
    ASSY EVAP-REF DA96-00013H (D/F Heater)
    ASSY TANK WATER DA97-00227D (Where split)
