Samsung rs20ccms Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Samsung rs20ccms This topic has 6 replies, 2 voices, and was last updated 4 years, 11 months ago by willz. Viewing 7 posts - 1 through 7 (of 7 total) Author Posts May 2, 2021 at 5:15 pm #99491 willzParticipant Water dripping from freezer at the front leg May 2, 2021 at 8:44 pm #476648 electrofixModerator is there a cold spot around the leg or is it dripping from the door ? Dave May 3, 2021 at 1:40 pm #476649 willzParticipant Have removed internal panel drain hole is blocked with ice and water runs down and seeps out of door corner May 3, 2021 at 1:46 pm #476650 electrofixModerator unblock hole and see how things go from there Dave May 3, 2021 at 6:31 pm #476651 willzParticipant Ok will do Thanks May 6, 2021 at 5:57 pm #476652 willzParticipant Ok for a few days, now leaking again and ice in bottom of freezer May 6, 2021 at 9:09 pm #476653 electrofixModerator sounds like you have a defrost problem you would need to check the continuity of the defrost heater Dave Author Posts Viewing 7 posts - 1 through 7 (of 7 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
