Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Samsung Rs20ccms
- This topic has 10 replies, 6 voices, and was last updated 16 years, 11 months ago by
Steven.
May 13, 2009 at 3:47 pm #45689
Steven
ParticipantHi Guys
I have been out to this f/f it has a fluffy ice formation top and bottom of the evaporator, defrosted and its back in a week.
All sensors and defrost heaters working, can any shed any light on why this is doing this at these places.
Door seals are sound, and c/x informed door to fridge is open no longer than it should be.
I can only think it allowing moisture or warm air from some where causing this but not sure.
Any suggestions please.
Steven
May 13, 2009 at 3:51 pm #286601iadom
ModeratorRe: Samsung Rs20ccms
Suggest you post it in the correct forum first, not Trade Vacancies. 😉
Moved you. 🙂
May 14, 2009 at 8:50 am #286602Steven
ParticipantRe: Samsung Rs20ccms
Thanks Jim for moving it here
It was late, i try and pay a bit more attention next time:oops:
Steven
May 15, 2009 at 10:20 am #286603Steven
Any Suggestions
May 15, 2009 at 10:24 am #286604spimps
Is the evap fan working and are temps in fridge OK ?
May 15, 2009 at 12:20 pm #286605Steven
The fan motor is working, thats the problem as the cooling is all done by the freezer, when the evaporator gets the fluffy ice forming it blocks the finns so the air does not blow through the evaporator hence the temp in to the fridge is affected.
Steven
May 19, 2009 at 4:28 pm #286606lee8
Do you have an evaporator in the fridge section ?
Samsung have had major issues with the over icing in the fridge compartment, to the point it reached the Watchdog programme.
If it is that one, basically its a crap design with no solution other than replacing the Evap cover, sensors, heat deflector to evap cover and pray.
The poly foam they used causes moisture trap and not heat to dry out, which causes the vents to block, temp to go funny and cancelling of defrost.
May 19, 2009 at 9:49 pm #286607850
Can I take it that this is a single evap type in the freezer? If so, when you check continuity of the heater you must seperate the connector for the upper and lower defrost heaters, otherwise one may have failed but the other is ok, but give the impression that both are fine. Also, with the fridge running normally, open the fridge door and listen carefully to hear if the damper flap is opening and shutting, by operating the door switch. There is also test procedure that you can go through but I would probably have to email a copy. Hope this helps. Good luck
May 20, 2009 at 7:44 am #286608Steven
Thanks 850
I will check those.
June 2, 2009 at 3:41 pm #286609Steven
Temperature reading on the display -25 freezer +3 fridge, actual temperature inside -12 and +8, this is due to evaporator blocked with fluffy ice again approx a week.
Why if there is such a difference in the internal temperature the display does not show this?
All heaters ok, if a sensor faulty surely this would show a fault code?
I read somewhere that there a modification to the freezer evaporator covers when you get excessive frost build up, could be caused by fan not running properly similar to some twin cooling models is this correct?
June 2, 2009 at 6:03 pm #286610Flyman
Sensors will show as a fault if they are basically open circuit or short circuit, not if they are just slightly out. Is there some reason the freezer is set to -25? This will generally produce more frost. If elements are both testing ok then I would probably change sensors, definitely the defrost one.
