Samsung RS20CCMS
  • #48683
    johnnyj
    Was asked to look at a Samsung RS20CCMS for a friend, the evaporator was iced up, i have deforosted the heater seems to be okay so i can only assume it must be a module or defrost stats or something similar, i would be grateful of any help on this one , jj
    #297365
    robbo1973
    Re: Samsung RS20CCMS
    generally the def sensor yellow wire.meter both heaters and therm fuse if all ok change def sensor.
    chris
    #297366
    johnnyj
    Cheers Chris.
    #297367
    johnnyj
    Got another one of these faulty i’ve checked the heater its okay, i think it may be the thermal fuse its tucked into the top of the evaporator this is open circuit trouble is i cannot find a part n/o for it can anybody help cheers JJ.
    #297368
    franz
    Hi JJ – connect website says obsolete but to use SAMDA4700095E instead
    Franz
    #297369
    johnnyj
    Thanks franz i’ll et it ordered jj
