Samsung RS20CCMS fridge freezer parts
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts Samsung RS20CCMS fridge freezer parts
  • #45565
    boselecta
    RS20CCMS
    90385428x800102j
    I require the freezer defrost heater and the freezer evaporator defrost sensor.
    Also where do you lot find your Samsung part?
    thanks
    #286190
    funkyboogy
    Re: Samsung RS20CCMS fridge freezer parts
    connect will have them..
    dont know what defo heater part no is , but defo sensor is da47-00006w.
    you probaly wont need the heater, its a bit of a common fault on these rs 20..samsung recomend changing sensor..its now modified. oviously change heater if its gone ?
    ally
    #286191
    boselecta
    Thanks for replying funkyboogy,
    I have found the defrost heater on the connect website but they list two yellow deforst thermistors!, which is correct?.
    DA47-00006W is not recognised by connect.
    Also are you lot now fitting the thermistor with the black end cap DA3200006U on this model?. (this is not recognised by connect either)
    #286192
    boselecta
    Does anyone know the part number for the freezer evaporator defrost sensor for a RS20CCMS? (its the yellow one that is held in a plastic case cable tied to the evaporator)
    thanks
    alistair
    #286193
    funkyboogy
    sory for late reply..
    defo sensor is da32-00006w its the same as the rs 21 sensor , now black in colour with yellow wire
    ally
    #286194
    boselecta
    ally
