Samsung RS20CCMS High temp in both fridge (18) & freezer
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Samsung RS20CCMS High temp in both fridge (18) & freezer
  • #55266
    Hi There
    I have a Samsung RS20CCMS, And the temperature keeps rising in both the fridge and freezer compartments. The Fridge is currently up to 20 degrees and the freezer is 4 degrees. The only way i can resolve this is to switch it off for up to 48 hours, then switch it back on and it works, but only for a week or two.
    Can someone please help me figure out the problem.
    Thank you,
    Samnanth
    #322468
    johnsdad
    Re: Samsung RS20CCMS High temp in both fridge (18) & fre
    probably needs defrost sensor
    #322469
    Kevin
    Defrost unit and see if problem persists if not its probably one of the following or all Defrost sensor /defrost heater/defrost drain heater or motor for circulation fan
